Hope Pro 2 hubs convert from 10mm bolt up to 10mm qr
morkz_media
Got some hope wheels second hand, but didnt realise they were 10mm bolt
So what im wanting to know I just order the Hope QR ends, but did i need to get a new axel assembly also or just the 2 x QR ends be sufficient.
thanks
Ivan
thanks
Your probably already know this, but the 10mm through axle will fit normal QR dropouts.
mint355
I converted from 10mm bolt in to x12 through axle. I had to get a new axle I think from what I worked out, the bolt up axle is different to all other configurations. eg there are 2 different axles one for the bolt up and one for the rest that hope offer.....
Ivan
Hope do two different versions of the 10mm axle Pro II.
One uses Allen bolts to secure the hub to the frame. These bolts screw into the hub. No axle is required.
The second uses either a 10mm bolt up axle or an oversized 10mm QR.
