Hi,
Yes i'm probably a dinosaur but I like to carry a frame mounted pump when i'm not racing and for local rides I don't like to carry a Camelbak, etc so it's nice to have my essentials attached to the frame.
Trouble is that my new Trek Fuel EX has a very fat and square downtube so my Lezyne and Older specialized pump brackets won't fit, they don't have enough offset, so the pump clips don't clear the downtube. Spacing up isn't an option either as the triangle is already barely large enough to get the bottle in and out of a side loading cage as it is and seat tube is a no go because of the dropper. Basically what I need is a mini pump with a bracket with plenty of offset.
The downtube has 33mm from the centre of the cage bolts to the edge.
Any suggestions greatly appreciated.
Cheers.
Cheers.
