Jesterarts
So, today I decided to take apart my hub (Hadley H500135 R2.1) because there is about 2mm of play in my rear wheel @ the tyre and also there is some grinding going on.
I took everything apart, had a look at the bearings, gave them a good clean out, greasing, put it all back together and its still grinding and wiggling.
So I put everything back together as I want to go riding on Sat and thought I would google what bearings I need.
This, is when my night went a bit pear shaped.
Everything I read says that I need 6804 bearings. Two of the same.
My issue is, the bearings i took out, the one on the drive side was smaller than the one on the non-drive side.
So the OD is different. Also the little space tube thing that sides between them also has a flange that fits in one of then but not the other. Though I think this might be more design.
Either way, the OD of the bearings is definitely different while everything I read suggest they should be the same bearing.
Please help!
Please help!
