Hi Guys,
Well this dilemma has been bothering me for some time now. Ive had a few 1/2 effort attempts to physically remove these dust caps on the hubs without success, ive searched and searched the net without coming any closer to the answer.
Tonight i gave my all, i tried using the axle to lever on them fron the inside, gently hitting the edge of the caps with a soft hammer and i spent an hour trying to rock the wheel in a vice with rubber softjaws holding one side and turning the other. With this method im positive i was able to move the rear dustcap opposite the freewheel side but i still could not remove it!
The freewheel side had a 'remove' arrow on it so with the other end in the vice after some time turning the dust cap in the direction shown eventually it undid and to my surprise the freewheel / cassette came off the hub and i had my first glimps of the internals, but alas i still couldnt remove the dustcap from the brake rotor side to see the bearing over there!!!!
Any help would be greatly appreciated, this is doing my head in. Ive lightly marred the larger dustcap on the brake side from rubbing on the rubber softjaws (rubbed off some of the black anodising) so ive conceded defeat for tonight!
Also, given i think i was able to partially move the brake side rear wheel dustcap, how do i press it back in? Is doing up the rear 142/12 axle tight enough to get it to reseat itself? Had i managed to remove it completely, what is the proper way to reassemble?
Travis.
Travis.
