I've been getting a heap of punctured so decided to give ghetto tubeless a try. I got it all set up and the bead sealed fine but there is a constant leak out of two spots on the seam between the sidewall and tread area. I've tried spinning the rim at all angles to get some of the sealant through it but it just won't stop leaking.
Should I try adding more sealant? The other option I was considering was ditching the tubeless setup and getting some tunes with removable cores (presta type) and adding sealant into the tube itself which should achieve the same. Have people had success with this? Is it hard to get sealant down a presta valve?
