Staunch
I'm in a bit of a pickle at the moment and was wondering if any resident suspension nerds could point me in the right direction.
My Fox X2 has begun to leak out of of the EVOL air sleeve, this being very evident as there in a point where the Float Fluid/grease combo is leaking/buldging out the bottom of the air sleeve. It's bad enough that it'll lose 200 PSI overnight, so the shock is unrideable. I've removed the air sleeve, re-lubricated the seals thoroughly, and reinstalled it to no avail, same leak still occurs. My issue arises which the fact that Sola Sport are undergoing a re-vamp after being bought out, and I can't get an answer and/or a new complete X2 service kit from them.
My question is, can I use the standard Fox Float air can service kit (803-00-142) just to replace the seals on the X2 which help seal the EVOL air sleeve? I can purchase of one these tomorrow in person which would be the fastest solution. The only rebuilt kit Fox lists for the X2 is 803-01-317, however I can't source one of those until Sola reopens and I'm impatient.
