mitchy_
Llama calmer
i've tried, without luck, to source the tool to remove the bore cap on Formula RX calipers.
does anyone a) know where i can get one, or b) know how to remove it without one?
if all else fails, i'm going to try use an L bracket like so filed down to fit in between the 2 opposing grooves. i'm not overly concerned about wrecking the finish on the ones i'm removing, however i was hoping i could install the new ones a little more gently (L bracket in a cloth? i presume they wont need a lot of torque applied)
