Fork Oil questions and queries.
fjohn860
Alice in diaperland
Supergliss is just a slide way oil, so any brand of slide way oil you can find locally will be sufficient I would reckon.
Maybe a engineering/machine shop might be able to sell some in small quantities.
I'm still dirty on the fact that my work just uses morlina 10 on the lathes and mill. Tried getting them on board with a way oil. But no dice.
anyone ordered Supergliss 100K from GKAsports? $40+$10 shipping
Any other local Aus sources?
Not local but look at it as a sweetener if you are doing a BC order at $28au.
EDIT: link
caad9
Anyone School me in the difference between 68k and 100k?
GKA only have the 68k in stock
Its for a Mezzer, btw.
At lower temps, 100k can get slow.
IIRC, at 7°C 100k will start to slow, 68k will go to 0°C, then 32k for the Americans riding in snow.
Thanks mate, does this create any issues with heat for the 68k?
No, apparently the 100K is the 'mostus' slidey oil, 68K just behind by a bees dick.
I have noticed the slow action of 100K after a cold night (2 or 3°C) and a morning ride, the fork was slow at the start, then got better later as the world heated up.
FWIW I now use 2.5wt Motorex Racing Fork oil on every fork. I was using a 50:50 mixture of Fox Gold and 100K supergliss but this other stuff is lighter and seems to work well if you keep on top of lower leg services, plus works well with open dampers.
