Everard
You may have built it, but I chose the parts from what I can remember!Of course it looks good Mike!
We built it!
haha
We built it!
Crank please tell me what you did! Yeah according to Pivot the Mach 4 is 12.8 but the Firebird is 13.85. So you are right. Just over 1 inch.The bb is 25mm higher on the FB than the Mach 4. Have you got the sag on the rear shock sorted out properly? I don't have any problems with pedal strikes or riding through rocks and the bb height is one of the things i really like about the bike.
Truvativ XC Carbon Cranks ( Gold Nugget )wow... nice.
ditto on the spec list!
Have you tested it yet?
I was thinking of either a Mach5 or Firebird for my next bike. Would be good to hear your first impressions!
Yea actualy - Aloy main frame and rear stays - the Big top rocker is all Carbonpretty certain, and without even googling, thats not carbon.
but other than the above, very nice bike.
Hey mate, nice bike yourself! Yes I did see another mates bike with that setup. I will think about it in the future. However my nice carbon chain ring and cranks all match at the moment with the black and gold and they look so sweet! I figure I will perservere and let the bike change the way i ride.Really nice machine, Everard.
Have you considered going a dual-ring + bashie setup on the front? This will definitely help your clearance issues, and improve your confidence through technical sections (though it doesn't obviously influence pedal height). At least this is what I found when I changed to a dual setup on my Intense 55.
Enjoy your new beast.
I think you're a prime candidate for a coil shock. The DHX Air will blow through it's travel on the FB if you don't run a bit more pressure than recommended if you are over about 85kg. I've tried mine with a CCDB and it felt excellent but find it runs more sag than i want using the same spring rate as i did on my Nomad. I haven't tried it with a stiffer spring yet.Crank please tell me what you did! Yeah according to Pivot the Mach 4 is 12.8 but the Firebird is 13.85. So you are right. Just over 1 inch.
So maybe I have not got the sag right? I am running a DHX on the back as you can see. I am 105 kilos and right now I have about 260psi in it.
I just guaged it by sitting on the bike and getting off and getting it close to 30%. But I am not too sure what to do about the mini booster valve or what to set the other features of this shock too?
I love everything about the bike except for the surprise hits I get from underneath. What do you recommend?
Well to really confess I am also on a diet and wanting to get down to 95 kilos!I think you're a prime candidate for a coil shock. The DHX Air will blow through it's travel on the FB if you don't run a bit more pressure than recommended if you are over about 85kg. I've tried mine with a CCDB and it felt excellent but find it runs more sag than i want using the same spring rate as i did on my Nomad. I haven't tried it with a stiffer spring yet.
Hey mate, yes I can give you all the information you need and photos.Awesome Firebird. Definitely a dream build. Well Done.
Got any more info on the Blur LT? I might be interested.
That's no reason to go on a diet!It's just a little daunting that I have to pump the shock up to 280 psi to achieve this.
Well that says it all doesn't it..Cant wait to ride it again. Learning to tame this beast has brought a new and exciting element to my recreation time.
