S.
ex offender
Is that a fact? So you maintain that thin-walled frames cannot be repaired eh? Funny... I work for someone who's made a living out of proving you wrong.If you think a lightweight, race-orientated cracked frame can just be repaired by welding, then you nothing about lightweight tapered-tube frames.
Don't care how good the repairer is, by the time you strip the paint, weld the ultra thin walled tapered tube (if you can get to it properly and retain anything like original alignment...) then re-heat treat the front triangle (so it doesn't just re-break around the repair weld) then repaint it, you might as well forget it.
The front triangle is gone. This is a bin job, except for pivot hardware and the back end.
The ad doesn't say it's fine to ride as is, it pretty clearly states that it's got a big crack in it. He even mentions repairing it, he doesn't try to claim "oh it's not structural" or "it won't get any worse" like some ads I've seen. If you really need someone to draw you a flowchart between "big crack in frame" and "this will end in disaster if you keep riding it" then you must be either under the age of five or have severe intellectual disabilities. The guy isn't kidding anyone, he's made it pretty clear that it's broken and needs fixing. He never said he continued to ride it whilst cracked, or that anyone else should, he said it WAS fine before, in other words, the rest of the bike is fine and not flogged out. Is it really that hard to understand?
