The lower idler isn't there to take up slack, it's to prevent the chain from dropping off the chainring (from the bottom first) on the rebound stroke of the suspension, when the chainstay length is dramatically decreasing a feeding "slack" chain back into the system via the derailleur. The lower guide also helps to ensure there's sufficient chain wrap around the chainring to reduce tooth wear while JRA.Not so sure they’d work. Point isn’t to tension, it’s to take up a ton of slack, and release it as suspension compresses and axle moves back 50mm.
