Hamo
Ok.. i did search and didn't find anything..
but I was thinking today... if you could change the type of gas (air)in an air sprung fork/shock... would it make any/ much difference to the performance of the shock... Ie.. Helium instead of the regular mix of gasses in the regular air).. or would the purity of the air (as in just one element or compound rather than a mix) make any difference... Ie..(not too good on chemistry) but if different gasses compress easier/ harder than others then maybe the compression would be inconsistant with mixed air?.. maybe not..?
meh.. I was just musing but thought I'd put it up here to see if it would actually make any difference or not..
(and for the weight weenies.. Helium in your forks.. woo)..
might be an experiment for someone who could work out a way how to get some helium or something into their forks?
