I am currently finalising my custom design for a ChiTi XC/Trail hardtail to be built around a 120m fork (likely Reba RL). I want the bike to get back into some XC racing but still provide "trail fun". I have based my design on the Kona Explosif and Pivot Les with 120mm fork.
I'm 189cm with 196cm reach and 35.5" inseam. I weigh 86kg naked and am an aggressive technical XC rider. Below are the numbers I've come up with:
HTA 68.5 degrees (static)
STA 72.5 degrees
635mm ETT length
425mm chain stays
44mm BB drop (306mm BB height with 700 tyre diameter)
520mm seat tube
130mm headtube
443mm reach, plan to run a 70-80mm stem with 730mm flatbar.
what do you think?
As a first time custom frame, I've got a few questions that I'm not sure what way I should go. Below are the tube dimensions I've been provided by the factory drawings, all tube thicknesses are 0.9mm.
I thought to use a 31.8 seat tube with a 27.2ID Ti or carbon post for comfort flex. Right choice or should I go for tubing with 30.9ID?
34.9mm toptube and 44.5mm downtube.
19mm dimeter seatstays, 25.5mm oval to 22.2mm round to 19mm taper chainstays. Both will have S-bends.
Given my weight and riding style the frame needs to be stiff, but I want it to still have as much of that buttery feel of titanium as possible. Will the above tube dimensions provide this?
Regarding drop outs, is it worth going 12x142 or just stick with 135QR?
It will be built as a 1x10 but I'm toying with the idea of dropouts that can be geared or SS. Is it worth the more complex dropouts just so I can "maybe run SS at some point in future"?
Is internal routing worth the hassle? I would run a full outer on the rear derailleur cable if external. I'm not too bothered about internal if its just for the purpose of cleaner lines.
Thanks in advance for any advice or ideas you might have!
STA 72.5 degrees
635mm ETT length
425mm chain stays
520mm seat tube
130mm headtube
what do you think?
