Hi all, sorry for the sp!
My X4 derailer (yes, yes) seemed to sort of curl its self back up towards the frame and was actually pushing against the frame, so i adjusted the screw that pushes against back away against the hanger(is it? its the thickest part.), and it holds, just. Were the screw touches the hanger, it has been chipped away a bit, so some just less than half the screw is pushin back nothing.
Will i be able to get away with that or will that part need replacing. i adjusted it, just to fine tune the gears, but that didnt really make much difference. How much clearance do i need between the 8th cog and the top pulley?
Thanks for your help guys. Let me know if you want more detail.
Below: will try and get pics.
