rangersac
Medically diagnosed OMS
First experience with this drivetrain and so far it has been frustrating. Mounted on a 2017 Giant Trance for junior, and initially the derailleur was in the wrong position as the hanger was for older derailleur types with the additional knuckle, which meant that I couldn't get enough clearance for the derailleur cage with the b-screw wound all the way in. Fixed that with the updated hanger type on the left in the picture below, adjusted limit and b-screws and off riding we went. After about five kays or so the shifting went to custard. Turns out the b screw had stripped the thread on the derailleur body, so now the cage was back in a position where it interfered with the cogs in higher gears. Is this just bad luck or does much larger 51T top ring need a specific hanger type because of the additional pressure on the b-screw? Not a chain length screw up, made sure that was long enough in the initial setup.
