http://www.corc.asn.au/event/gravity-enduro/
4 downhill sections with 30 minutes between.
$50 plus $20 MTBA day license should you need it.
I've been speculating on how you'd run 4 routes without overlaps. Current theory is this:
Question marks are:
Wedgetail - would you run it from the top or from where it crosses the fire trail after casuarina - likely the latter, or just run it from the top of pork barrel.
Rollercoaster - note sure if you'd bother or not, however it prevents staging conflicts between that and slick rock or pork barrel, plus it gives two routes up the hill (either the trunk climb or casuarina then the fire trail the crosses wedgetail
Little Seymour / Breakout - just not sure where you'd go from here. You'd end up with people almost needing to climb heartbreaker to get up to the top if they haven't already done all three from the top and make it in time.
Any theories?
EDIT: Stage 1:
https://www.youtube.com/watch?v=cApYwuVyZ6Q
- Wedgetail(?) / Pork barrel or slick rock / double dissolution
- Rollercoaster (?) / Skyline / Northern express / little seymour (?) / Breakout(?)
- Downhill track
- Luge from under the shipping container/ Duffy to the bottom
Question marks are:
Any theories?
EDIT: Stage 1:
