with a big stick
Unno?If it makes you feel better that might be going too!
Space Force? Huh?Should've gone to Spec-Savers
I didn’t go for the cheaper WTB i35’s…because obviously 35 is too wide for my needs.Yeah I grabbed the 29ers and they’re 35mm which is probably the max I will go, you can always sell them on Facebook for a profit.
On the plus side if you'd gone with the cheaper WTB i35's you may have wound up with a 28H hub and been extra pissed.I didn’t go for the cheaper WTB i35’s…because obviously 35 is too wide for my needs.
Also true.On the plus side if you'd gone with the cheaper WTB i35's you may have wound up with a 28H hub and been extra pissed.
FARK! I didn't notice that I guess I better lose some weight and maybe invest some Cushcore or the like, dammit, well there's my confession tooOn the plus side if you'd gone with the cheaper WTB i35's you may have wound up with a 28H hub and been extra pissed.
Those double wides were...well very wide. Your new wheel choice sounds almost impractical?And then some. I think D32’s (external probably) were the widest I ran back then. Wider than Sun doublewides.
Thanks, Captain Obvious...Those double wides were...well very wide. Your new wheel choice sounds almost impractical?
Personally, the colour and matt finish look like they'd be perfect matchy matchy for those Carbonda things I've seen around.Turning his back on the gravel scene after a surge in popularity, @moorey is now trying to find solace amongst the Plus tyre crowd. Do not go boldly my friend...
Is the Stanton plus tyre compatible?Personally, the colour and matt finish look like they'd be perfect matchy matchy for those Carbonda things I've seen around.
Luckily I have trail wide Maxxis in the spares pile, bought for the Hope 35w's I tend not to ride due to being wider than I need.....
I guess we’ll soon see….Is the Stanton plus tyre compatible?![]()
"It's not 29", it's 27.5+!!!"Is the Stanton plus tyre compatible?![]()
Or a 27.5+ Carbonda. You’re just faffing, trying to mullet a 29er."It's not 29", it's 27.5+!!!"
He's inching ever closer...![]()
Hubs yes, rims no.Or a 27.5+ Carbonda. You’re just faffing, trying to mullet a 29er.
Should I bring them to the Youies for you?
Why yes, yes I do.Sounds good. Do you still have those 2 new 2.8 Wild Enduro's?
Not for your specific situation...but for bikes in general. The big rim + big tyre but not fat tyre scenario seems like a silly set up. Plus tyre I think beebinson just called it.Thanks, Captain Obvious...
Yes. Plus tyres were a big thing. The 2.6-2.8 fad was fully sick for a while.Not for your specific situation...but for bikes in general. The big rim + big tyre but not fat tyre scenario seems like a silly set up. Plus tyre I think beebinson just called it.
