So after getting some 180mm XT rotors off
@hifiandmtb I decided to install them tonight, so after 30-40 mins trying to find the 180mm i.s. mount I knew I had somewhere, I go ahead install them.
The front is nice and easy as it was already 180mm just SLX so just a rotor swap and alignment tweak.
Now swap the the mount for the rear, swap rotor go through alignment of caliper beautiful no rubbing sweet. Before I finish I’ll just double check the mounting bolts for the adapter, damn it I didn’t tighten them
just threaded the bolts in. Okay tighten bolts then redo the align again no noise, now I’ll double check the front bolts just to make sure I did tighten them up, okay I least got them right.
