born-again-biker
Is looking for a 16" bar
Should my Charger damper suck & squirt splash lube out of the small hole near the top?...or is it leaking damper fluid 'coz something is buggered?
In the middle of a lower leg service on my Yari's tonight. Done many times before on RS products.
While I was feckin' around cleaning & lubing the lowers I noticed the damper side of the uppers was dripping oil into the pan for ages.
Hmmm....
Didn't think much of it at first because I just had the forks upside down while I was tapping the bottom bolts to free the lowers. I figured the splash oil
was running back out slowly ....but it didn't really stop at what I thought was "about 10ml"....
So I unscrewed the whole damper rod from the upper and had a bit of a fiddle on the bench. It's definitely responding to changes in rebound/comp OK.
It squirts & gurgles oil outta the little hole near the top at full compression....?
There's no nasty bits in the rod travel - it feels smooth from top to bottom when I move it by hand.
As I said, I've done plenty of lower leg services but I've never dived into a damper.
Should I be worried?
I rode it this 'arvo, pre-service, on my local trails & the fork felt fine.....I think....
Hmmm....
