Disco
Ok, this is not your average question... i'm chasing some tech opinion.
I run a singlespeed RM Flow (73mm BB shell, vertical dropouts) with a 13-25 gearing, the 25t being on a Truativ Luftalarm Disc with 1/3 bashplate.
I also like to sprocket grind!
So the problem lies in the chain tension. I ran a new chain (KMC Gold) with a half link for the last few weeks, and the chain tension was slightly loose, but it wouldnt jump off. But now the chain has worn in, the tension is quite loose and i dont want the chain to fall off... well obvious reasons!
I have previously run a sprung tensioner and thrashed the hell out of it and my dropout, and a Rennen rollenlager too, but I'm not to game to mount things on my dropout hanger. I can't really run a bottom roller from a chainguide and swing it back for tension, because the smallest most chainguides go to is 32t and mounting on the BB shell would be dodgey, you cant really space out the 73mm shell like you can a 68 and just run a 73.
So this is where I stand. The only other solution (Other than new dropouts Grip style... cmon its a brand new frame!) Is mounting a tensioner along the bottom of the chainstay, sliding it along the horizontal axis to loose or gain tension, like those Ging style rollers... but they are made out of a pissy plastic side plate on each side of the roller and also are too long (ie sit lower than hight of the chainring) for grinds.
All i could think of is a home-made guide (proper) that slides along the chainstay and bolts into position.... with a roller like a fixed upside down U shape made out of chopping board style material that the chain would sit on.
Please lend me your ideas on how to do this... DECENTLY!
Michael
(If all else fails i spose i could run the rennen... but it's not preference)
Michael
