No. 100mm max. Extension of fork is set by air spring rod and rebound damper rod. You could make these longer but then the stanchions would be too short and would not overlap the lower bushings properly.
For 120mm you need a reba or '11 120mm SID. Longer stanchions and reba-like lowers to provide room at the bottom for the longer stanchions.
