Pretty sure recent Rockshox air-sprung forks cannot be lowered from their original travel (or positions in the case of dual position adjust) without changing the air shaft itself to the travel you desire (140mm,150mm,130mm etc).
In the old days it was a matter of putting spacers on the shaft. Now they have a new air spring system in which a dimple is recessed into the stanchion, which regulates the pressure in the negative spring as the fork cycles. If you use spacers on the same travel air spring, it will bugger up this system and the fork won't ride properly (so I'm told)
EDIT: not sure if this hold true on the boxxers/totems/lyriks. Pretty sure it only applied to forks that used to have dual air springs like Sid/Reba/Revelation etc...
