Disco
I was running a Shimano Deore Caliper on my old forks (Pyslos and Dukes) and it worked fine... as they fitted the direct mount (6" ISIS) on the caliper. (BRM-555's dont use an adaptor...) Now my dillemma is I am now running DJ1's (2003, 20mm Bolt-Thru) and there seems to be about 7mm of space (parallel to the axle) between where the caliper sits on the disc and where the caliper should bolt onto the tabs of the fork. I cannot just space the caliper out, as then it only runs on about 3 threads of the caliper mounting bolts. Do i have any other options other than just Going to a bolt shop and getting longer bolts and using washers to space my caliper away from the fork?
HELP!
Michael
HELP!
Michael
