nakedape
As the title says, my rear brake howls worse than when Bronnie found out she couldn't use a chopper to go shopping anymore - but only when I'm coasting (not braking).
The problem started a while ago, and each time it would start I'd find that the axle was loose - which made sense, i.e. loose axle allowing the rotor to wobble. I've loctited the axle but the howl persists.
Rotor is tight, pads are new.
I've trued the rotor as best as I can without a lathe and finger indicator (it has about 0.25 wobble left in it). Also re-adjusted the caliper. Both of these see the howl disappear for half a ride but after a few big bumps it comes back.
I'm open to any suggestions...
