I have the four bike version and it looks to me you need to loose the mounting plate under the ball to locate it better with the rack (to keep it level as well as line up the locating plate). It also doesn't appear that you have the rack tight enough as it looks that the ball mount is not pulled in quite enough, I find wiggling the rack whilst tightening the knob then locking the bolt with a spanner. Once the ball mount knob is as tight as you can do by hand they don't move. As it's sitting it looks nearly right.Hi Guys,
I was wondering if anyone has pruchased the car bike rack (Click HERE.
I had purchased thisunit a while ago, when it was on sale. But never used it since my friend had a ute for transport. Now that he doesn't, I decided to pull it out the other day only to find that the ball mount, does not sit flush with the plate it comes with. Which means that the entire contraption is only fixed and resting on the to ball. This makes it very unstable.
Item is now out of warranty, doubt I will be able to return it. Just wondering if anyone else has had any issues. Attached a photo of connection for reference. View attachment 307863
Cheers in advance...
The bolt to secure the tow ball is fully loosened, I even took it out. I cannot get the outer cone closer to the plate, no matter what I do to the top knob. I have even removed the scre that stop the tow ball collet from falling out.Loosen off the bolt, wind out the knob as far as it goes. The outer cone should finish flush with the silver part inside the cone. Wind down the knob firmish (not too tight or it'll be a bitch to undo), and then crank up the locking bolt on the side.
The hitch only fits on the ball and is not ment to sit down on the tounge.
two hands, knobs, flappy bits, ball mount, I'm not sure we are taking about the same thing. HAHA :heh:Yeah I think I'm the same as what the others have said.
Ensure that before you put it on you totally wind out the knob before attaching it.
Then I find the best way to put it on is to lift the rack with my left hand and 'lean' my right hand down on the knob (Eg the force of gravity should push the knob into your right hand).
Then slide the knob over the ball mount, ensuring the flappy metal bits go fully over the ball mount.
Then tighten it all up.
I dont believe it sits flush, but will try get a picture for you tonight.
I'll buy into this discussion Cameron.So with that in mind, I'm looking for a towbar mounted rack with a channel system designed for 1 bike, that can be removed quickly and easily.
User name botch + home made rack = this will end well :thumb:Can you weld? And do you have a welder?
I made a rack specific for my bike which was originally made to be bolted the towbar tongue with the ball. My current car has a 50mm hitch mount, so i modified it to suit that.
Takes about 30 seconds to get it from the shed to my car and mounted, then about a minute to get my bike out and onto the rack.
I'll try and find a pic if you want to see it
do you not get a lot of wobble with that?Better late than never.
Looks mine sits similar to the one pictured, except mine is possibly laying flatter?
Mine is the same as his no wobbles as it tightens down on the ball pretty harddo you not get a lot of wobble with that?
+1, I have one and it stays put and doesn't swing around. The OP needs to loosen the knob more until it fits over the tow ball.Mine is the same as his no wobbles as it tightens down on the ball pretty hard
Got mine and used it over the weekend.. this is exactly how it sits. Given the way it mounts, I really don't see how it could possibly sit flush with the plate below unless you're doing something wrongBetter late than never.
