That's about right. The big difference is that the F1 doesn't kick your pedals where the D8, you must wear clips to stay on top. I haven't run clips since the Fatty Fat, 2000.top_dog said:I got about 54mm as well, and I get 38 for my D8 also.
.61 of an inch isn't a difference? We're talking BB height, that's a huge difference.---Matt--- said:uDi... you do realise that you're talking .61 of an inch (15.49mm)... which is just .11 of an inch (2.79mm) more than the travel difference between the Canfield and the PDC. Honestly... you're saying that you can't dispute the figures and I agree... to a degree... but 2.8mm differece isn't that great (and neither is 15.49mm really) and that would most likely be made up in sag alone. Honestly, I don't see how 2.79mm is gonna make up that much of a difference.
One thing to note with Linkage is that it uses an arbitrary scale AT ALL TIMES for the curves - it will basically stretch or compress the curve(s) in any direction to fit the size of the graph (that red line would be nearly dead flat on a scale from 0-1). While that looks like a huge difference in rate, if you look at the actual numbers on the right hand side of the graph (those are the "gradient" figures), the gradient varies from about 0.3025 to about 0.33, then back to 0.307ish. This is not a great deal. The easiest way to see this is by looking at how much the blue line (direct travel/stroke comparison) VARIES from being straight (as that scale is much larger on a relative scale). As you can see in that graph, it's nearly a straight line anyway, hence the suspension being very linear. You will also notice the scale thing more if you directly compare two bikes. Be super thorough if you do that though, because it doesn't take much of an inaccuracy to totally throw the shock rate out the window.top_dog said:Suspension curves
I realise that S. thats why I said that when I posted the rates.top_dog said:it is only minimal and you could probably get away with calling it linear.
At 0mm it has a leverage ratio of 3.3:1
At 135mm it has a leverage ratio of 3.03:1
At 229mm it has a leverage ratio of 3.24:1
So not that big a deal it would have been nice to have a steady curve though.
