Yes, and I'd recommend avoiding it unless you really set on it.I've got a Giant/DT Swiss hub that has what I assume is anodising that is flaking off in a couple of spots. Anyone had any experience at having alloy parts stripped and re-anodised?
They're hubs I bought for a wheel build. Had bought them on the understanding they were in perfect nick, but consistant with my luck of late with machinery the rear hub is not cosmetically perfect. They look like theyve been stored in cold wet conditions for a while.The only justification (given the price and risk barriers) for doing this is of you're going purple.
Yes you can mate but be aware for every 2/1000" of coating 1/1000" of raw metal is consumed in the bonding process, the strip the previous anodization layer you will loose that metal, so make sure no part of the item is measurement sensitive.Can you get something anodized like a suspension link.. if it's already anodized a certain colour?
Me? OCD? Don't know what you're talking about... :eyebrows:Peeling paint gives you cancer, throw them in the bin.
Or clean em up and respray, but do it fast, those chips are already messing with your OCD for unmarked parts.
No actual impact marks on them, and id expect to see scratches not flaked paint (?). Meh. I'll still use them, at least they're not on the front hub I can see when riding!Interesting pics Haakon, clearly cosmetic marks that won't affect performance, but how they got there is a bit of a mystery. As Mrlinderman suggested, it looks to be an anodised look-alike surface finish.
Perhaps there was a quality issue with Giant and the raw aluminium was not properly cleaned before the finishing coat was applied. Or, the previous owner had little regard for looking after his spare hubs and they bounced around in his tool drawer for a bit before you bought them.
If the coating continues to flake off, I'd be thinking it was a manufacturing problem, but as they're second hand you'd have little chance of a warranty claim.
If they were my hubs, I think I'd just go to an auto shop and get one of those stone chip repair paint pens and touch up the marks. You'd need to look hard to see your touch up work and it would probably be fairly resistant to being cleaned post ride.
That looks liks a good way to clean cassettes. A buddy picked one up to clean parts from an old engine he is rebuilding, pretty amazing before and after pics on 30 year old parts that were covered in baked on crud.Hubs look painted. If looks are super important, remove the internals and bearings, get the outside sandblasted and give them a coat of paint. Sand blasting will give the parts a finish that paint will stick too like crazy. I've re-done many alu parts with this approach. If good quality paint is used, then they will stay looking good for a long time. It helps if you have your own blasting cabinet, but if you get it done, just tell the guys to not remove any material from the bearing seats / sealing surfaces.
