http://australianmountainbike.blogspot.com/2011/03/press-fit-bottom-brackets-why.html
<div><span class="Apple-style-span" style="font-family: Times; -webkit-tap-highlight-color: rgba(26, 26, 26, 0.296875); -webkit-composition-fill-color: rgba(175, 192, 227, 0.230469); -webkit-composition-frame-color: rgba(77, 128, 180, 0.230469); font-size: medium; "><div style="font-size: 18px; -webkit-text-size-adjust: none; background-image: initial; background-attachment: initial; background-origin: initial; background-clip: initial; background-color: rgb(255, 255, 255); background-position: initial initial; background-repeat: initial initial; ">AMB's Oli K caught up with Shimano's Greggy Chalberg to press him (get it?!) for answers about press fit bottom brackets.
Why did shimano go to a Press fit BB?
Customers (frame manufacturers) were asking for it.
Why is that?
Having a bottom bracket shell with thread and having to design a frame to accommodate an external cup on each side was restricting.
Why did Shimano go with their current system (over say a BB30)?
When Shimano originally released the external bearing two piece crankset back in '02 they determined that a 24mm diameter axle was the optimal for strength to weight ratio, stiffness and also minimising friction from the rotating BB bearings. It also allows them to use steel as an axle material without a weight penalty. A BB30 system requires an oversize axle to give stiffness but axle made of steel would be bring a weight penalty as it wouldn't be possible to make the steel thin enough to keep the weight down for this application. Shimano feels aluminium is an inferior BB axle material compared to steel. Shimano chooses to use steel on all its high end axles for durability and peace of mind.
Testing at Shimano Japan reveals that the oversize bearings in the BB30 system cause a measurable increase in friction compared with Shimano's press fit bearings.
It allows us give people the option (manufacturers and riders) to use press fit without having to change to a new system of cranksets. Perhaps one day we'll see Shimano produce BB30 bottom brackets/cranks as well, because people are asking for it. At least there are manufacturers out there making adapters for running our two piece 24mm diameter axle cranks on a BB30 equipped bike.
Advantages of the system
More scope for frame design.
Compatible with current 2 piece cranks.
Lighter by 30g (30%) over XT external BB.
Less pedalling friction compared with BB30.
Potentially more weatherproof than the external bearing BB system, not because of the quality of the bearings but because they are less exposed to water when tucked inside the bb shell (note - this is Oli's theory and has yet to be proven – STAY TUNED!)
Disadvantages
Specific tools required for installation and removal (retail about $300 for both)<span style="line-height: 18px; padding-left: 36px; ">
More...
Why is that?
Disadvantages
More...
