mxracer92
just starting out the pedalling game , have never really gotten into it until i had a house break in and ransacked , stole a heap about 40k worth of stuff inc my 2010 yz450f race bike , which had a heap of money spent on it.
sadly the bike was NOT insured but the house stuff was , and part of the robbery haul was an old 05 kona , which wasnt worth much.
new for old i had 3500 to spend at a bike shop .. came home with one of these
2009 norco a-line pk ed , with the full saint lineup (copy n paste from manufacture specs, cause i dont know a heap about bike parts , but learning slowly whats good and whats not )
FRAME- Hydraformed AL, adjustable travel, 199mm-227mm travel, adjustable headtube angle, bb height, 1.5� forged headtube
FORK- Marzocchi 888 RCV, 203 mm of travel, 1-1/8� steer tube
REAR SHOCK- Fox DHX-3 w/ factory tuned ProPedal
HEADSET- FSA Orbit E 1.5� R reducer internal 1.5� to 1-1/8�
GRIPS- pro taper pillows
HANDLE BAR- Truvativ Hussefelt 710 mm x 25mm rise, 31.8mm, Grey
STEM- Marzocchi clamp on direct mount 53 mm / 63 mm extension
SEAT POST- Truvativ XR double bolt, 27.2
SADDLE WTB- Silverado custom cover, chromoly rails
FRONT BRAKE- Shimano Saint, 8� rotor
REAR BRAKE- Shimano Saint, 8� rotor
BRAKE LEVERS- Shimano Saint
SHIFTER REAR- Shimano Saint rapid fire
REAR DERAILLEUR- Shimano Saint, 9 speed, medium cage
CASSETTE- Shimano LX , 9 speed, 11-32T
CHAIN- Shimano CN-HG-53, 9 speed
CRANKSET- Race Face Evolver DH or Shimano Saint, 170 mm 36T, E-13 SRS Guard with Translucent Red guard
BOTTOM BRACKET- Shimano Saint
PEDALS- Flat pedal with sealed bearing, steel pins, grey
FRONT HUB- Shimano Saint, 20mm axle
REAR HUB- Shimano Saint, 150 x 12mm, 9 spd
SPOKES- Stainless steel, black 2.0
RIMS- WTB Laser Disc FR 30 mm, 32 H, Grey
TIRES- WTB Dissent 26 x 2.5, high grip compound, DH casing
its pretty hard work on the trails so i found out , after a almost full lap of kalamunda loop , ( almost died and got some vehicle help back to my car )
so i went looking for something that will pedal a bit easier and found this 2nd hand with very few kms on it !
i prob got ripped a bit for what it is ( dam hock shops !! about 1k for it ) but im happy with how much less effort it rides , not real keen on the paint colour thou .. nothin a strip and powder coating cant fix.
2007 specialized stumperjumper comp
FRAME- FSR M5 manipulated alloy frame w/ Transform monocoque TT, sealed cartridge bearing pivots and rear shock mount, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 120mm travel
REAR SHOCK- Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.75x1.75"
FORK- Fox Float 120 RL, 120mm, rebound/compression adj, lock out, alloy steerer
HEADSET- 1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM- Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
HANDLEBARS- Specialized XC low rise 31.8mm OS bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 620mm width
TAPE / GRIPS- Specialized MTB, dual density
FRONT BRAKE- Avid Juicy 5, hydraulic disc, G2 Clean Sweep 203mm rotor
REAR BRAKE- Avid Juicy 5, hydraulic disc, G2 Clean Sweep 185mm rotor
BRAKE LEVERS- Avid Juicy 5
FRONT DERAILLEUR- Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
REAR DERAILLEUR- SRAM X-9, 9-speed, long cage
SHIFT LEVERS- SRAM X-7, aluminum trigger 9-speed
CASSETTE / FREEWHEEL-S himano HG50, 9-speed, 11/34t
CHAIN-SRAM PC-951 w /Power Link
CRANKSET- Truvativ Stylo, 2pc crank/BB
CHAINRINGS- 22S/32A/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKET- Truvativ GXP, sealed outboard cartridge bearing
PEDALS- Some junky haro ones , no idea on specs
RIMS- DT custom for Specialized X430, 24mm w/eyelets, 32h
FRONT HUB- Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
REAR HUB- Shimano M-525 disc, 32h, alloy QR
SPOKES- DT Swiss 1.8mm stainless, black, alloy nipples
thanks for looking , let me know what ya guys thinks , if any perth riders keen for a pedal , hit me up.
