Recently got a new bike with Elixir 5 brakes. The rear disc rubs slightly on the inside surface and the lever is a bit tighter than the front one. Shining a light up the brake pads I can see the disc is closer to the inside pad than the outside one.
I attempted to realign the brake following the instructions by loosening the two hex bolts holding the brake to the bike frame, then depressing the brake lever and tightening the bolts back up. Although this improved the issue it did not fix it entirely. I've repeated it a couple of times but when I tighten the bolts the housing shifts back to being slightly off centre from the disc.
I'm guessing that I'm right at the edge of the available movement the brake attachment bolts are allowing for my brake. Is there anything else I can try or should I simply take it to the shop to get fixed (still under warrantee)?
Thanks
Thanks
