wkkie
It's Not Easy Being Green
Item: Various listed below.
Item Condition: Various listed below, mostly brand new.
Reason for selling: Not being used, left over from a couple of builds.
Price and price conditions: Listed with each item.
Pictures: With items below.
Uberbike ceramic Shimano bottom bracket. Brand new.
$80 posted
Uberbike oil slick tubeless valves. Brand new.
$25 posted
Uberbike adaptors, various. Brand new.
$10 posted
Nukeproof Horizon tapered headset, purple.
ZS44 top, EX44 bottom cups.
Top cup installed into frame, but not built up or ridden. Bottom cup brand new.
$50 posted
Ergon GA2 grips, purple reign. Brand new.
$40 posted
$80 posted
Uberbike Bottom Bracket Ceramic 68/73mm - Purple. Shimano HT2-Raceface MTB/Road Compatible
The Uberbike Shimano Hollowtech 2 and Raceface X-Type compatible bottom brackets have been specifically designed for use with either 68mm or 73mm BSA threaded MTB or Road bottom bracket frame types using a 24mm spindle diameter chainsets. The bottom bracket cups are CNC machined from lightweight...
www.uberbikecomponents.com
$25 posted
Uberbike Airtech CNC Alloy Tubeless Valves 40mm - Oil Slick
Our custom Airtech 3 air hole design base for increased airflow when using co2 and stronger than standard aluminium valves
$10 posted
Uberbike Disc Brake Adapters
Optimize your braking setup with our Disc Brake Adapters. Achieve perfect alignment and compatibility in just seconds.
$50 posted
Nukeproof Horizon Top Headset Cup
Nukeproof Horizon Top Headset Cup Nukeproof have launched a range of headset's which use the titanium coated race bearings with stainless steel balls. The titanium coating is applied using Physical Vapour Deposition, which means that the material is vapourised in a vacuum environment and then...
nukeproof.com
Nukeproof Horizon Bottom Headset Cup
Nukeproof Horizon Bottom Headset Cup Nukeproof have launched a range of headsets which use the titanium coated race bearings with stainless steel balls. The titanium coating is applied using Physical Vapour Deposition which means that the material is vapourised in a vacuum environment and then...
nukeproof.com
$40 posted
GA2
The do-all MTB grip. Including an inboard aluminum clamp, the rider has the ability to ride wide on the handlebar and contact nothing but soft rubber. Maximized and designed for all MTB applications. Design & Innovation Award by Enduro Mountainbike Magazine Online Grip and Size Selector...
ergonbike.shop
