Disco
So heres how the story goes.
I was on my way to go and finish building my new bike, and i had my rear
juicy five in the boot of my car.
Cut the story short.
A car battery tipped over, and spilled hydrochloric acid all over the brakeset.
Yes, i washed it copiously with water as soon as i found out / could,
but the acid had destroyed the outer of the hydraulic line.
What sort of negative effects has this caused with the brake?
Would the pads have been contaminated?
There is a risk the acid has damaged/weakened more than the outer,
so what may have been effected? Seals? Fluid?
How do i know if this is damaged?
The brake is a 2006 Avid Juicy Five, which means the brake fluid is
dot 3/ dot 4 (NOT mineral oil i think...) and there are no visible leaks of fluid.
Any help or suggestions is greatly appreciated,
Mikey.
Mikey.
