So I bought a 7.875x2.25 Bomber CR for the Six but am having a bit of trouble deciding on spring rates. I'm putting in 120kg for rider weight and 170mm travel and the Cyclinic calculator is giving me 800lb whereas the Fox one is anywhere from 700 (30% sag) and 800 (25% sag).
The current shock is one of those DNM RL cheapies and sits at about 50% with 200psi in it. I'm not too concerned about running 30% sag as I'm more of a cruise down the hills than pedal madly up type, but I don't want too much sag either cause it doesn't lock out and from memory there's a bit of pedal bob. I don't know how much bob I'll be able to tune out with the compression adjustment if any as the last coil shock I used was an 03 Vanilla R.
Does anyone have any input re spring rate calculators with regards to how accurate they might be? I get it's going to be a feel thing but I've read some of the results can be not quite right and I'd rather not have to buy twice...
