Driftking is correct. Rear sprockets are the same thickness, spacers between are thinner on 10 sp. Hence 10sp chain is also slightly thinner.I guess the other question would be, will a 10spd chain work in a 9spd rear, cassette and derailuer? I imagine that the actual rear sprockets in a 10 spd might also be a tad thinner than in 9spd.
10sp Shimano rear derailleurs have a different motion ratio (relationship between cable movement and corresponding derailleur movement) to 9 sp and wont work.Along the same theme, tempted to try a 10sp shadow plus Derailleur on my 9sp setup. The way I see it, the shifter is indexed, so I can't see a reason the 10sp wouldn't actually work fine. That said, sometimes my theory and practice are out of kilter. :wacko::wacko:
Have you (or anyone) actually tried it or are you going on what you've heard/read? Don't get me wrong, you're probably right, but there's a lot of 'incompatible' stuff out there that runs perfectly. Next time i see a cheap 10sp rear, I'll give it a crack.10sp Shimano rear derailleurs have a different motion ratio (relationship between cable movement and corresponding derailleur movement) to 9 sp and wont work.
Even I wooda questioned a 9sp derailleur with 10sp shifter!!!im currently running a 10spd setup with XO 9spd derailleur, XO 10spd shifters and 9spd XT front chain rings with 10spd chain. all fuctions perfectly.
Good luck. From what I understand though is that Shimano have gone from their old 2:1 actuation ratio to something closer to SRAM's 1:1...but they don't say (or I haven't seen it) precisely what the new ratio is. For that reason you might have trouble. Sometimes though if you can reroute the cable entry into the pinch bolt you can change the working geometry slightly...might help if you have issues.Have you (or anyone) actually tried it or are you going on what you've heard/read? Don't get me wrong, you're probably right, but there's a lot of 'incompatible' stuff out there that runs perfectly. Next time i see a cheap 10sp rear, I'll give it a crack.
I can't be arsed going to 10sp across all my bikes yet, but I'd love to see if the shadow + does all it claims to.
This makes sense because SRAM rear derailleurs have always been 1:1 actuation. If the actuation ratio remains the same it works because the shifters just pull/throw less cable so the RD movement is less for each shift.im currently running a 10spd setup with XO 9spd derailleur, XO 10spd shifters and 9spd XT front chain rings with 10spd chain. all fuctions perfectly.
Yes., I should have specified my comment applies only to Shimano ('cause that was what moorey referred to).im currently running a 10spd setup with XO 9spd derailleur, XO 10spd shifters and 9spd XT front chain rings with 10spd chain. all fuctions perfectly.
That setup does not work for Shimano gear. Google it, there is plenty of evidence on the web.How does the 9sp derailleur work with 10sp shifter, regardless of ratios?
1. The shifter is indexed to move a little less on a 10sp, About half of the index increment of a 9sp shifter
and 2, the problem of more shifts than gears? If it moved the same amount as 9 sp then you could just lock out one of them and it would work. Thats how we could run 8sp shifters on 7 sp cassettes back in the day.
I'm clearly missing something here if that setup works :bowl::bowl:
Ok, I'm still missing the point I guess, because you have one more click than sprockets, and each sprocket is a little closer together. I believe you if you're saying it works, I just still can't get my small brain around a 9sp shifter running smoothly on 10sp derailleur and 9 sp cassette without it shifting a little too much each time, regardless off pull ratios.
Edit. Reading back, you didn't specify if cassette was 9 or 10sp. I was assuming 9sp. If its 10sp, I geddit.
I learnt the hard way > a M773 rear mech (10sp shadow) can not be used to replace a M772 (9sp shadow) given 9 speed XT shifter and 9 sp cluster. the cable pull ratio is different meaning you can only get around 5 or 6 cog spread, and it rattles and carries on like a bitch. It just does not work.Ok, I'm still missing the point I guess, because you have one more click than sprockets, and each sprocket is a little closer together. I believe you if you're saying it works, I just still can't get my small brain around a 9sp shifter running smoothly on 10sp derailleur and 9 sp cassette without it shifting a little too much each time, regardless off pull ratios.
