Frame -2013 Specialized enduro comp (med)
Rear shock - Custom FOX Float CTD Evolution with AUTOSAG, Climb, Trail, Descend settings and rebound adj
shock/fork - FOX 34 Float CTD Evolution 26, air spring, tapered alloy steerer, Climb, Trail, Descend settings reb adj., 15mm thru-axle, 160mm
Handlebars - renthal fatbar lite
Stem - renthal duo mount
Headset - 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
Grips - ODI X-treme lock-on
Saddle - Body Geometry Henge Comp, hollow Cr-Mo rails
Seatpost - KS supernatural
Front brake - Avid elixir 5
Rear brake - Avid elixir 5
Cranks - Custom SRAM S-1250, 10-speed AM double
Front chain ring - Renthal SR4 ultralite alloy chainring
Chainguide - E13 LG1
Chain - KMC X10, nickel plate, reusable Missing Link
Rear derailleur - SRAM X9 Type 2, 10-speed, mid cage
Rear shifter - SRAM X7, 10-speed, trigger, w/MatchMaker clamp
Cassette - SRAM PG-1030, 10-speed
Front hub - Hope pro 2 EVO
Rear hub - Hope pro 2 EVO
Front rim - Stans flow ex
Rear rim -Stans flow ex
Tyres - Maxxis high roller II/Maxxis minion DH
