naz is your man for info on them, or you could just try the serch function and find a buttload of threads about them.............dhr208 said:Im getting myself a .243 frame for some DJ action, has anyone got one or heard much about them?
not at all unweighted the headangle is around 64, but with sag its around 66 to 67 (and i am running them at 8inch) im surprised riding downhill it feels awesome the front end is tank, and the rear is light so its flickableriderigid said:how does it ride with 888's? did it screw the geometry at all or are they the special ones you can get from zocci that have 170mm of travel?
Hrm, well, at 4kg a frame, it's a fairly hefty base to build on, considering alot of DJ frames are 1-1.5kg lighter than that. It's so easy to get stuck in the "overbuild to hell" mentality, you think if you've got a tough frame you might as well build the rest tough, and in the end you finish up with a monster of a bike :xstooge said:I recommend the .243, they really arnt as heavy as every one says, they ride quite light, also depends alot on the build you choose.
Well, 3.4kg to be exact :lol:Rik said:Hrm, well, at 4kg a frame
True thereRik said:it's a fairly hefty base to build on
I agreeRik said:It's so easy to get stuck in the "overbuild to hell" mentality, you think if you've got a tough frame you might as well build the rest tough
Yep, thats why i said it depends on how you build it :wink:Rik said:and in the end you finish up with a monster of a bike :x
