Item: 2016 Specialized Camber S-Works 29 - Medium
Item Condition: This bike has been ridden and has a couple of love taps on fork RHS and seat stay LHS to prove it, see photos.
Reason for selling: One of my bikes is going to a home where it will get ridden more often
Extra Info: The concept behind the S-Works Camber Carbon 29 is pretty simple: If speed is your thing, it's the only trail bike you're ever going to need. Essentially, it blends all of the trail bike characteristics that you want with the XC climbing prowess that you need. This is achieved by thoughtfully combining our full FACT carbon fibre Trail Chassis with a carbon Camber FSR rear end. At both ends of the bike, you'll find sufficient travel lengths that deliver plenty of plush suspension—all without going overboard on big hit capability. This means that you don't have to sacrifice efficiency, weight, or sheer speed to ride how you want. And with our Trail 29 Geometry and lightweight, stiff, and smooth Concentric Pivot at the rear, we can guarantee it. The other trail component of the Camber is utility, and along these lines, it features our fully integrated SWAT Door at the down tube of the frame. Open it up, and you're able to safely and securely house your ride essentials right where you want them—on the bike. For the build, we selected components like SRAM XX1 and Shimano XTR brakes that hold nothing back in delivering unadulterated, supreme performance. Add it all up, and you get one bike that can quite literally do it all.
Specifications:
DRIVETRAIN
CHAIN SRAM PC-XX1 chain, PowerLink, 11-speed
BOTTOM BRACKET SRAM PF30, OS press-in bearings
SHIFT LEVERS SRAM XX1, 11-speed, trigger
CASSETTE SRAM XX1 cassette, 11-speed, 10-42t
REAR DERAILLEUR SRAM XX1 rear derailleur, 11-speed
WHEELS
FRONT HUB Roval Traverse, sealed cartridge bearings, 15mm thru-axle, 100mm spacing, 24h
REAR HUB Roval Traverse SL, DT Swiss Star Ratchet, 54t engagement, SRAM XD driver body, 12mm thru-axle, 142mm spacing, 28h
SPOKES DT Swiss Revolution
FRONT TYRE Purgatory, Control casing, 29x2.3", 60TPI, Aramid folding bead, 2Bliss Ready
RIMS Roval Traverse SL 29, carbon, disc, 30mm inner width, 24/28H
REAR TYRE Slaughter, Control casing, 29x2.3", 60TPI, Aramid folding bead, 2Bliss Ready
COCKPIT
SADDLE Optioned with Body Geometry Phenom S-Works, Carbon rails, 143mm
SEATPOST Command Post IRcc, 12 position micro-height adjustable, alien head design, bottom mount cable routing, remote adjust SRL lever, 30.9mm, 125mm travel
STEM Syntace F109, 6-degree rise, 31.8mm clamp
HANDLEBARS Specialized Trail, FACT carbon, 6-degree upsweep, 8-degree backsweep, 27mm rise, 750mm width, 31.8mm
GRIPS Specialized Lock-on, XL thickness
SUSPENSION
FORK RockShox RS-1 29, Solo Air spring, 120mm of travel, compression adjust, rebound adjust, Spike Valve, inverted design, 1-pc. tapered carbon crown/steerer/uppers, 46mm offset, 15mm Maxle Ultimate thru-axle
REAR SHOCK FOX/Specialized remote Position-Sensitive Mini BRAIN, AUTOSAG, Spike Valve, BRAIN Fade adjust I-Valve, Kashima coating, 205x53mm
BRAKES
FRONT BRAKE Shimano XTR, hydraulic disc, Ti-metallic pads, 180mm Ice-Tech rotor Ice-Tech rotor
BRAKE LEVERS Shimano XTR, carbon lever, I-spec
REAR BRAKE Shimano XTR, hydraulic disc, Ti-metallic pads, 160mm Ice-Tech rotor Ice-Tech rotor
FRAMESET
HEADSET 1-1/8" upper, 1-1/2" lower, threadless, Campy style, cartridge bearings
SEAT BINDER Alloy, 34.9mm
FRAME FACT 11m, full carbon chassis and rear end, Trail Geometry, SWAT™ Door integration, PF30 BB, fully enclosed internal cable routing, Concentric Pivot link, 12x142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 120mm of travel
Pictures:
Specifications:
DRIVETRAIN
WHEELS
COCKPIT
SUSPENSION
BRAKES
FRAMESET
Pictures:
