WarehouseNo27
Just picked this up after getting back into mountain biking on a Cannondale Scalpel.
Thought I would take a few pictures before the first ride. :Banane01:
Frame - 2016 Giant Trance Advanced 1 (Large) - Advanced-grade composite w/ ALUXX SL rear triangle, 5.5" Maestro suspension
Rear shock - Fox Float Factory
Front shock/fork - Fox 34 Float Factory Kashima w/ 15mm thru-axle, OverDrive steerer, 140mm travel
Handlebars - Giant Contact SL, Low rise, 31.8mm
Stem - Giant Contact SL
Headset - FSA/Giant
Grips - Giant squiggles.
Saddle - Giant Contact SL neutral, SST tubular metallic rails
Seatpost - Giant Contact SL neutral, SST tubular metallic rails
Front brake - Shimano XT, Hydraulic disc, [F] 180mm
Rear brake - Shimano XT, Hydraulic disc, [R] 160mm
Cranks - Shimano XT, 32T
Chainguide - none
Chain - KMC X11SL DLC
Pedals - Shimano PD-M424 SPD Pedal
Front derailleur - none
Rear derailleur - Shimano XT, Shadow+
Front shifter - none
Rear shifter - Shimano XT, 11sp
Cassette - Shimano XT 11-42T, 11sp
Front hub - Giant PTRX 1 Composite WheelSystem; 28h, [F] 15mm axle
Rear hub - Giant PTRX 1 Composite WheelSystem; 28h, [R] 142x12 axle
Front rim - Giant PTRX 1 Composite WheelSystem; 27mm wide, Tubeless compatible
Rear rim - Giant PTRX 1 Composite WheelSystem; 27mm wide, Tubeless compatible
Spokes - Giant PTRX 1 Composite WheelSystem; Sapim Race, 14/15g
Tyre Front - Maxxis Minion DHF 3C TR 27.5x2.3
Tyre Rear - Maxxis High Roller II 3C TR 27.5x2.3
Tubes - none
Total weight - 11.5kg (haven't weighed it, from web) + pedals.
All stock except for tyres, tubeless & pedals.
ps - posted this last night but have no idea where it went. can mods delete the other thread if its doubled up?
Headset - FSA/Giant
Chainguide - none
Tubes - none
