AzonicNick
Hi all,
Looking very seriously at picking up one of these.. am I correct in thinking that the 1 is a good upgrade over the 2, the forks, the drivetrain and brakes are the big ones.
http://www.giant-bicycles.com/en-au/bikes/model/trance.27.5.1/14919/66471/
But want to go into this with my eyes open.. A couple of quick questions..
Is the fork on the 1 a big step up? Talas on the 1 and Float on the 2. The guy in the shop said the Talas is a much better fork. The only thing on paper different is the travel adjustment on the talas? but the guy in the shop said it is much more adjustable? Is this right?
The fork is Giants OverDrive2. Now since I am planning on keeping this for a few years I am lead to believe by the local shop that if I want to change my forks down the line I will require new forks, headset and a stem. Is this correct? I don't want to be locked into OD2 forks moving forward.
Also the rear wheel is 135mm but the frame is 142mm, it has some sort of spacer. This shouldn't be a problem if I want to swap in some new wheels in the future? This would be the first big upgrade. There is mention of this in the flow review here.. http://flowmountainbike.com/tests/tested-giant-trance-1-27-5/
Finally if I wanted to get rid of the front detailer etc with the existing clutched rear derailer all I would need is a NW ring and possibly some shorter bolts correct?
Is there anything else I should know about before picking one of these up? I want to make sure I know what I am getting into before dropping $3400 on this thing! Thanks for all your help. Any feedback is appreciated both positive and negative.
Cheers,
Nick
Cheers,
Nick
