Mad4singletrack
My Mountain
2014 Fox Racing Shox forks & rear shocks in store @ www.MyMountain.com.au
It's that time of year again. While we're slowly receiving snippets of information from various bike brands about their 2014 range, Fox Racing Shox has been busy getting their new forks, shocks and dropper posts out in time for the new riding season. We've just received our first shipment of 2014 Fox product, including the incredible 40 FLOAT RC2 downhill fork, as well as the DOSS dropper posts and CTD rear shocks.
Being an authorised Fox Racing Shox dealer, My Mountain is able to pass on the savings to you, the rider, so you can get on your brand new Fox fork at a ripping deal. We'll also be offering upgrades to CTD remotes for compatible forks, and as always, we're your go-to suspension service centre in Melbourne with a full range of spare parts ready to give you fork and shock the TLC it deserves!
2014 Fox 40 FLOAT RC2 FIT: $2279 RRP
Our Price: $1961
"The impressive Fox 40 returns for 2014, albeit with a brand new chassis to make it without doubt, the best downhill Fox Racing Shox has ever produced. Released back in 2004, the original Fox 40 burst onto the downhill scene with it's massive 40mm stanchions and oversized construction that redefined expectations of..." Read more here.
2014 Fox Float X CTD w/Trail Adjust: $839 RRP
Our Price: $744
"The FLOAT X is a brand new shock for 2014, and has been designed specifically to address the needs of the emerging Gravity Enduro market. Engineered from the ground-up as a replacement for the existing DHX Air rear shock, the FLOAT X CTD utilises an additional piggyback reservoir built into the main body of the shock to house additional damping oil and shim stacks. This larger reservoir allows the damping oil..." Read more here.
2014 Fox 34 TALAS 27.5" 160/130 FIT CTD w/Trail Adjust: $1639 RRP
Our Price: $1393
"The travel adjustable TALAS fork from Fox Racing Shox provides you with the ability to drop the fork travel down to 130mm in order to lower the cockpit position for climbing and tight sections on the trail where you need more weight on the front wheel. Introduced over a decade ago, the original TALAS fork bolstered a growing Fox Forx range to offer riders a new level of suspension performance and durability..." Read more here.
2014 Fox 32 Float 26" 100 CTD: $899 RRP
Our Price: $798
"For maximum performance-per-dollars, there's no need to look any further than the Float CTD fork. Introduced over a decade ago, the Fox FLOAT fork redefined what riders could expect from a lightweight suspension fork. With its beefy 32mm stachions, stiff one-piece magnesium lower and smooth action, the original Fox FLOAT set off a true revolution in high-end MTB suspension.
For 2014, the Float continues to get better and better..." Read more here.
New TALAS
New for 2014, the redesigned TALAS air spring makes a dramatic departure from previous versions by utilising a coil negative spring instead of the negative air spring found in previous TALAS forks. Mimicking the revered smoothness of the FLOAT forks, the new TALAS internals utilise a single O-ring in place of the previous 3, providing a much more supple action that removes any of the previous compromises with choosing a travel-adjustable fork.
- Updated damping tunes for even greater control
- New and improved remote
- Improved air spring curve
- Low friction
- Crisp actuation with precise internal travel range
Mounting Hardware
Small Parts. Big Difference.
The main contact point of shock-and-frame has been redesigned to offer big benefits.
Less Friction: The new resin hardware reduces friction by nearly 50% compared to traditional mounting hardware, allowing the shock to respond faster to all linkage movements.
Clean and durable: O-rings and the flanged bushing design blocks out dirt and mud. In lab tests, shocks submerged in muddy slurry lasted 10 times longer with the new hardware.
No tolls required: All pieces to the hardware system can be mounted to the shock and removed by hand.
Self-contained: Shocks are shopped with all the hardware in place. No more zip ties, cutting or prepping - just mount and ride.
Kashima Coat
Butter-smooth, Genuine Kashima Coat's distinctive gold color is backed by its high performance attributes - properties that provide an exceptionally smooth feel and extreme durabiliy.
Superlight Chassis
Lightest ever. Just as strong.
The lightest ever FLOAT 26, 27.5 and 29 forks are here with zero sacrifices in stiffness or performance. These short-travel forks feature the same weight-saving engineering as seen in the 34, resulting in unmatched torsional stiffness and trail performance.
For more information on the range, head to www.MyMountain.com.au to see all the 2014 Fox Racing Shox gear as well as pricing and all the setup information you need.
Our Price: $1961
Our Price: $744
Our Price: $1393
Our Price: $798
Some of the standout features on the 2014 Fox Racing Shox range
New TALAS
- Low friction
Mounting Hardware
Kashima Coat
Superlight Chassis
