This is my 2008 Norco Rampage. Everything is pretty much stock apart from the brand new Marzocchi 55 rc3 forks. As you can see in the picture of my old forks they were pretty much rooted.
Frame 6061 Alloy heavy duty shore inspired tubing and geometry, hydraform DT, milled HT, chainstay yoke
Fork Marzocchi 55 RC3 ,160mm travel, 20 mm axle , alloy steer tube
Headset FSA Orbit MX alloy, Cartidge bearings, deep cup
Cranks Chainguide Truvativ Hussefelt, 22/32/bash guard, Howitzer Spline BB
Pedals Wellgo LU-A52, sealed bearings, replaceable pins , flat pedal, White
Chain SRAM PC 59
Freewheel SRAM PG-950, 9 speed, 11-34
Front Changer SRAM X-7, low clamp, 34.9
Rear Changer SRAM X-9, 9 spd, medium cage
Shifters SRAM X-7 SL trigger, 9 spd
Bar Syncros Gain, 7075 aluminum 40mm rise, 31.8mm
Stem Syncros AM stem, 31.8 White
Front Brake Hayes Stroker Trail hydraulic, 8" rotor
Rear Brake Hayes Stroker Trail hydraulic, 7" rotor
Brake Levers Hayes Stoker Trail
Front Hub KT QR-20, sealed bearings
Rear Hub Shimano Deore 6 bolt disc
Rims Sun Equalizer 29, 32 hole white
Spokes DT Swiss Champion stainless black 2.0
Saddle Norco Shore, short profile
Seatpost Syncros Derived 1 pc alloy 30.9, 350mm
Chain SRAM PC 59
