2008 Giant Trance X1, first mtb build
Andrew Prentice
Frame - 2008 Giant Trance
Rear shock - Fox RP2
Front shock/fork - Fox float RL 32 F120
Handlebars - Truvativ 710mm wide
Stem - Truvativ Holzfeller 50mm
Grips - Jetblack
Front brake - Shimano Saint M810
Rear brake - Shimano Saint M810
Cranks - shimano zee 170mm
Pedals - Nukeproof Proton
Rear derailleur - Shimano Saint M810 9 speed
Rear shifter - Shimano Saint M810 9 speed
Cassette - 9 speed deore
Front hub - Nukeproof generator
Rear hub - Shimano Zee
Front rim - Sunringle MTX29
Rear rim - Sunringle MTX29
Tyres - High Roller 2.35
Blue = Stock
Red = Custom Build
teK--
I like how you've run full length housing for the rear section the shifter cable. Would love to see the tube stay wrapping tidied up a bit though; try pulling it taught as you're winding it.
See what I did. (I ended up doing the same to the seatstay as well)
ChopSticks
Banned
great frame with lots of potential upgrades to be made!
like Tek said.... spend abit more time wrapping the rear swing arm and it can look really nice!
lose the electrical tap and use a zip tie or double sided tape instead.
this is what I did with the missus Trance:
Also.. if you really want to run full length outers... consider what I did
Use the supplied tabs, but run a section of outter where the exposed cable would've been.
Andrew Prentice
Just had a tune up ride out on the yarra trail, bike is riding a treat, them wheels are heavy though, had an Ivanhoe jump session as well :p
So happy with the build
