The other thing to consider is the A2C will be taller, for the same amount on travel, between the 32, 34 & 36 platforms. The 34 & 36 are quite similar, but there's a bit of a difference.
For instance, I was looking into what would happen if I changed from my RS Revelation 150s to a Fox Float 36 @ 150mm (adjusted internally), and came up with about 8 - 9mm. That would mean that at the full 160mm, there would be almost 20mm difference, or almost a full degree, between the two forks on my bike.
I'm still considering doing the Float 36 @ 150mm, but the RS Revs are still performing quite well at the moment!
