MTBcrash
Item: POLE Evolink 150 - Medium
Item Condition: Used, few marks from use as expected. Bought new in Aus around 2018, used by a 50yo bloke until 2020 and has been used sparingly since by my sons partner. Small cable rub from internal dropper cable. Some small chain slap on seatstay. Everything else is really good condition. 3mm foam on downtube was installed since new.
Reason for selling: Surplus
Price and price conditions: Sold
May consider a swap for an XL frame and shock with 150-170mm travel and 500mm or greater reach
Extra Info:
• This was Poles V1 150 Evolink built for 27.5 but has been only used as a full 29er. V2 was the 158 and dedicated around 29" wheels which started having the cracking issues with the new designed rear triangle.
• Happy to provide more photos to show there are no cracks.
• Despite the signs of use around the rear triangle yoke, tyre clearance is no issue with 29" wheels, mainly used with a 2.4/2.5" tyre.
• ISCG05 chainguide tabs (x3 for full guide)
• Medium Size (480mm reach) most large sizes these days.
• Rockshox Monarch RC3 Plus shock, just been serviced by NSR-Racing in Tassie, not been used since.
• (8.5x2.5" (216x63mm)) shock size.
• Standard 22.2x8mm hardware top and bottom.
• 30.9mm seatpost
• 34.9mm seatclamp
• 200mm Max Seatpost insertion
• 460mm seat tube length
• ZS44/56 Headset
• 135mm headtube length
• Threaded 73mm bottom bracket shell
• 148x12 (Boost rear hub spacing)
• May have 142x12 adapters too.
• Standard IS brake mount
• Minimum rotor size is 160mm from memory.
• Chainstay length - 455mm
• 77.5° Seat angle
• 63.5° Head angle
• Designed for a rider around 170-180cm
(I'm 185 and it felt good, stable bike but good to manoeuvre around)
May be able to offer a set of 29" Lyrik RC2 170mm forks for additional price with the frame.
Pictures:
Will do tomorrow on the way to Thredbo. Need to shrink them
Extra Info:
• 30.9mm seatpost
• 34.9mm seatclamp
• ZS44/56 Headset
• 77.5° Seat angle
• 63.5° Head angle
Pictures:
