wkkie
It's Not Easy Being Green
The short legged spider. Originally full 29 inch, but I've been playing and trying out different setups for the last one and a half years and have come up with what I like best which is the full 27.5 setup.
More fun and nimble with the little wheels and still loving the gearbox and belt!
Frame - Zerode Katipo, 505.
Headset - Cane Creek 40.
Shock - SR Suntour Voro coil, 525 lb Nukeproof SL spring. 230 X 65 (160mm W. enduro link).
Fork - 29in SR Suntour Durolux RC2, 170mm (590mm A2C).
Stem - Unite splatter, 31mm, 31.8mm clamp.
Handlebars - Chromag Fubars OSX, 800mm, 25mm rise, 5 deg up, 8 deg back.
Grips - Raceface Grippler, 33mm, cut down for the grip shift.
Cranks - Pinion CNC, 165mm.
Pedals - Unite Instinct splatter.
Bottom Bracket / gearing - Pinion C1.12.
Chainring & rear cog - Pinion Gates Carbon Drive, stainless 39t.
Belt - Gates Carbon drive, 122t.
Brakes - TRP DHR Evo.
Rotors - TRP, 203mm, 2.3mm thick.
Wheels - 27.5 Lightbicycle AM730, 30mm internal, 36mm external, 32 hole, on boost Onyx Vesper front and 142mm single speed Onyx Classic rear.
Front Tyre - Maxxis DHR2, 2.6, EXO TR, W. Huck Norris.
Rear Tyre - Maxxis HR2, 2.4, 3C Maxx Terra EXO TR, W. Huck Norris Sandwich.
Shifter - Pinion DS2.
Seat Post Clamp - Unite splatter.
Seat Post - OneUp components 240mm, 31.6mm.
Dropper lever - OneUp components, Ispec II clamp.
Seat - Dartmoor Trail v2.
Weight - 17.35 kg.
To gain a little more clearance I threw on the 165mm CNC cranks and have no issues with bottom bracket height which is pretty much spot on at 340mm, which lost about 8mm from the full 29 setup at 160mm travel up front.
New wheels, suspension and decals all round since the last update. Also fitted some fresh rubber up front and new drivetrain bits.
Weight - 17.35 kg.
