XT Boost cranks in non boost frame
whichway
Squid
I want to buy a LR power meter and they are all based on boost cranks.
Can I install a shimano XT boost crank in a non boost frame (11 speed, but that should be OK) and will it work OK.
Can I get a chain ring setup that works for this?
Is the Q factor different?
I can't find anything on crank dimensions etc
whichway
Squid
Can I just fit a 3mm spacer between the crank and the chainring so that the chainline is back at the non boost line.
whichway
Squid
I thought my bike was boost, but it's not. This is about the difference between boost and non-boost, not 11 and 12 speed.
Sorry, I miss read your original post as non-boost cranks in a booth frame. I still wouldn’t recommend spacing out the ring by 3 mm.
Halo1
Now every pedal stroke you are going to be thinking would this be better with boost. New bike time.
Thanks for asking as this is helpful for me as I have both a boost and non boost frames.
PJO
in me vL comy
I'm currently running a non-boost crankset in a non-boost frame with 1mm spacers because I wanted the chainline to be 49mm and the original was 50mm.
Just need longer chainring bolts
Chriso_29er
This says 8120 chainline is 55mm.
https://bike.shimano.com/en-NZ/product/component/deore-xt-m8100/FC-M8120-1.html
This says the 8000 chainline is 53.4mm
https://bike.shimano.com/en-EU/product/component/deorext-m8000/FC-M8000-B1.html
Does this mean that the difference in chainlines between 8000 non boost and 8120 boost is only 1.6mm?
Also with the direct mount I didn't think there were any bolts for the 1x shimano.
That is the difference between M8000 'boost' and the 8120 ' boost'
New Gen shimano is hella confusing. Apparently now 52mm chain line M8100-1 will work with both non-boost and boost! Used to be 50.4mm Sounds to wide for non-boost to me. But may be due to differences with cluster position on microspline?
Then you have 55mm 'boost' M8120-1 and 56.5mm M8130-1'super boost'
