franco cozzo
im using these atm as a rear and i agree...its fastThe Monorail is also a fast rear.
what tyre have you found it pairs well with up front?
Aspen! 10 charim using these atm as a rear and i agree...its fast
the TB's are rad tyres! they roll SOOOOOOOOO well.Just got a pair of Thunderburts in the mail. Very light, very thin, look sorta like mini-me racing ralphs. I don't think I'll bust these out for Redesdale this weekend
i've got a brand new 26x2.1 Rendez if you're looking... was going to ditch it shortly as it's no use to me.I was running it with the somewhat hard to find 2.1 Maxxis Rendez. Later I was running it with the 2.25 Ardent up front. Not a bad combo at all for fast trails and moderate loose over hard, light gravelly stuff.
He's probably sorted Mitchy, check the post date.i've got a brand new 26x2.1 Rendez if you're looking... was going to ditch it shortly as it's no use to me.
I gave this thread a bit of defibrillation this afternoon.
Think I missed something. The 50psi/MTB bit.Tyre: Maxxis Brentjens DNA S490 2.1
Strength: Light weight, fast
Weakness: Flats way to easily even under 50psi, if using as a front tire it will take a while to get used to the lack of grip, as a rear tire horrible on gravel over hard ground as it just spins and gets your nowhere.
Weight: 500g
Bottom line: Wouldn't recommend unless your racing on smooth hard ground
So I have used the thunderburts for a while now. Very, very fast on smooth hardpack. Surpisingly grippy on that surface.Just got a pair of Thunderburts in the mail. Very light, very thin, look sorta like mini-me racing ralphs. I don't think I'll bust these out for Redesdale this weekend
BUT.......very. very fragile. Mine are the non-snakeskin version and they performed miserably at Stromlo. Heaps of snakebite punctures, and if pumped up to avoid punctures, no grip.
Currently got an Ardent Race on the front with a complete suite of acronyms, and am impressed so far by the grip, durability and rolling resistance.
I've tried, but the rims on the bike don't hold a tyre well enough to get a reliable seal. I can put brand new tyres on and off these things with no tyre levers in about 30 seconds.Run your burts tubeless!
Why are you running tubes in any tyre?
Had the same issue with some non-TLR EVO Schwalbes quite a few years back (NN front / Ralph rear). The mammoth effort took bottles of sealant, buckets of soapy water, a compressor and my entire swear-word vocabulary (which is extensive and multi-lingual) to get them sealed at the rim (they just wouldn't "snap" and properly lock) and then I realised I'd had to use so much sealant that they ended up the same weight as the Snakeskin versions, but were still less reliable.I've tried, but the rims on the bike don't hold a tyre well enough to get a reliable seal.
Ha, that's awesome!Had the same issue with some non-TLR EVO Schwalbes quite a few years back (NN front / Ralph rear). The mammoth effort took bottles of sealant, buckets of soapy water, a compressor and my entire swear-word vocabulary (which is extensive and multi-lingual) to get them sealed at the rim (they just wouldn't "snap" and properly lock) and then I realised I'd had to use so much sealant that they ended up the same weight as the Snakeskin versions, but were still less reliable.
:mmph:
Somehow, I got through 1 six hour race (the Gods must've witnessed my epic effort at getting them sealed and cut me some slack), but after that, they didn't survive any more rides unscathed. Went back to Specialized's 2Bliss tyres, stopped having sealing problems and promptly vowed never to waste time with a non-TLR tyre ever again.
Mavic 719 ( I think, something like that).What rims are they?
Tried the rubber strips?
