Wheel Build Advice Thread
PJO
in me vL comy
@ozzybmx is your tension up to the same level when you finish a wheel now compared to a few builds ago? Tension meter could need recalibration?
Well tensioned spokes shouldn't need anything to hold them in place, I have used engine oil, loctite, and linseed oil. Haven't noticed a difference in the final result.
Do you measure final tension with tyre inflated at running pressure?
PJO
in me vL comy
Well there’s your problem! You’re using interior rated oil! Since you’re riding outdoors you need to switch it up for some exterior decking oil… :p
Actually you are onto something there @beeb. Tung oil should work well and polymerise faster than (raw) linseed oil.
It took me about 6 hours to get a wheel apart once where someone used linseed oil, I was tempted to cut the spokes but there weren't the easiest to source. I've only ever used anti seize and never had any problems.
Make sure you leave a few soaked old rags lying around.;)
385532
ausdb
Being who he is
If you can get it cheap I reckon it would be a really handy addition to the tool box for emergency repairs. Not sure I would build a whole wheel out of spokes threaded with it though
These things do roll the threads not cut them. Waste a few old spokes and set it up properly, use some sort of lubricant and they do a good job. It looks like they've changed the design in the last few years. It doesn't take that long to do a wheel worth once you rig up some sort of a stop so you get repeatable thread length and you can take the handle off and put a battery a drill on if your too lazy to turn the handle.
SummitFever
This. I have always just used engine oil on the spoke threads and anti seize on the rim hole (applied with a cotton bud).
Wheels build up easily and can be retensioned at any stage without issue.
The nipples can not unwind if the spokes stay under proper tension.
Yeah it might be an issue with tension but the nipples are spinning by hand, there is no resistance (dried linseed) at all.
I always do my final tension with no tyre on... never had a problem before. Usually around 110kgf.
The Park Tool tension meter I use is the one I have always used, it may need calibration but I dont just rely on the meter. I have built enough wheels by now that I know how they should feel by hand and by sound.
I just use the meter usually to get a ballpark and check consistency.
Has me a bit baffled to what has gone wrong.
Build dry.
Might be an option.
Going to try and get some new Linseed onto my Deviate's rear wheel tomorrow.
Might be an option.
If you're trying to deal with wheels that are already built, get a 10ml syringe and put some Lanotec in it. It penetrates very well as a liquid but dries out to a tacky anti-seize. Drip some on the threads and the rim holes and then re-tension. Don't use loctite blue or purple.
My guess is that the linseed oil has turned into a hard lacquer and powderised.
shiny
Go-go-gadget-wrist-thingy
Not built a wheel yet and I have been reading Roger Mussons book, he uses engine oil on spoke threads and a dab on the eyelet.
Not watched Ali Clarkson's vids as yet. Let us know how you go @ozzybmx
I've never had an issue before, even straightening a wheel that I have built, there's resistance unscrewing the nipple. Same unscrewing the Linseed bottle lid.
Something is definitely gone amiss with the old Linseed oil.
Will look into the Lanotec.
Cheers
ausdb
Being who he is
Are there any mavic gurus here? I noticed a spoke had come adrift on my sons rear wheel the other night whilst I was fixing a puncture. It's an old 26 crossmax SL.
385560
As we're away and I have limited tools I managed to unscrew the nipple from the rim and remove it, but the nipple looks well and truly corroded to the ball end of the spoke.
385561
I'm guessing I need to start unicorn hunting for a replacement but has anyone ever tried or managed to get one apart without destroying it? Some hamboing has suggested hot water as well as the usual soak it in penetrating oil.
Dip it in vinegar mixed 50/50 with warm water. That might loosen the corrosion between the spoke and nipple, or it might completely fuck the nipple. Then use penetrating oil if the nipple doesn't fall apart.
lightbrain about 4pm
Or 50/50 acetone and ATF. Don't waste your time with wd40. White vinegar is best.
