What do your kids ride?
How hard was it to convert to a 9spd hub?
I wasn't clear, sorry. Remove spokes, throw hub at wallaby eating my fruit trees, re-lace new hub:behindsofa:
I've got a spare formula hub in great nic you can have for post cost if you want a crack at it. I needed a disc hub, btw. Formula is also a disc hub. Does your bike have disc mounts?
Mica
As Moorey was kind enough to point out I have doubled up significantly by posting "What do your kids ride" under the general section of this forum (I haven't brought myself to admitting I'm a vet and belong in the old mans ward of rotorburn so have missed this completely).
Here's how my son is starting out....
eastie
My girl is on a 16 inch specialized hotrocks she got when she turned 4. Nearly two years later and shes finally almost back to the confidence, speed and ability she had on her wooden balance bike, i kick myself that I didnt take the cranks off and use it as a balance bike.
If i had i would've found out sooner that the crank bearings had no grease, and on looking further nor did the rear coaster brake hub. Short story is with new properly greased bearings in the hubs and bottom bracket she can now spin the cranks, coast along and climb hills with ease.
Do your kids a favour if you didn't build their bike yourself check their bike is properly assembled and greased! Fuck you Specialized/Trailmix, for $300 grease where it should be would be nice!
silentbutdeadly
has some good things to say
I redid the cranks and wheel bearings of the lads 16" Giant Animator (or whatever) that I picked up at the tip shop for ten bucks before Xmas...then promptly had to strip the crank out anyway because being not even four and only just hitting 110cm tall...he's not quite tall enough for it. So it'll be a balance bike for a while yet. Clearly they'd never been greased apart from at assembly and even then not had enough...perhaps Giant and Specialized use the same kiddies bike maker?
SuchisLife
This is my 20 month old girls current ride, we call it the drift beetle because man does she get sideways. She also has a plastic trike that she hammers down the driveway on. What's everyone thoughts on a good age to get a balance bike?
gead
My boys have moved through the Byk range, but the oldest (6yo) now has a shiny new trek. Ignored suspension and tried to get the lightest bike I could find...9kgs
JoelFitz
Awesome! I couldn't find anything without suspension when I was looking
Sent from my Galaxy Nexus using Tapatalk
Slowman
I put this together for my son a year ago. He's 7, almost 8 now. It has been upgraded a little, we've gone from SRAM X7 to X9, I've put my old AC350 wheelset on it. It's a Malvern Star XCS extra small frame. Could have gone for a 24" wheel bike but they all had crap suspension and components so I built this instead. This is lighter than his old 20" wheeled bike!
pistonbroke
We got our girl a balance bike pretty early. She was probably 18 months old. But she's only really started riding it after 24 or 26 months. Didn't matter and I never pushed the issue. I would just get it out every couple of months and try and help her with it. She was never interested for more than about 10 seconds until one day something just clicked and she was off.
So my advice is it's never too early to buy one but don't push them into it. Just offer it up and see how they go. If it doesn't go well, give it some time. I've also seen kids doing tricks and jumping logs at 18 months. Everyone's different.
Slowman
Yeah that's often how it is, when they're ready it just clicks and away they go. My daughters were like that. I had my son on a razor scooter probably from about 2 to 2.5 and bought him a bike at 3...but I made the mistake of getting one with training wheels. They are very bad as they learn nothing about balance and even come to rely on them. I ended up taking the pedals off and using the bike as a balance bike for a week or 2 and then put the pedals back on and off he went. I did the same for his younger sister and it worked too. This Christmas she got a new Merida Dakka 624 24" wheel bike with rigid forks (the suspension forks are a waste of money and heavy as).
Danny B
You see HEAPS of kids on the trails over here in Rotorua. A lot of the younger kids who are seriously into it are riding around on kids race bmx's. Nice very light looking bikes. The older kids (around 10-12 say) then seem to graduate to XS 26" hardtails and then onto single-crown dualies by their early teens. Quite different from when I was a kid.
eastie
I managed to pick up last years giant veer 3 speed 20 inch for a steal at YVC for an upcoming 6th birthday. Thought the same as others with forks - rigid is light and simple. Weight loss program has commenced ....
- 140mm steel cranks > 125mm sinz alloy,
- 38t steel chainring > 35t sinz alloy
- wide no name chain > 10sp sram hollow pin
- giant saddle > specialized kids saddle
- giant grips > esi chunky's (off my bike after tearing one - cut down now for 3speed grip shift)
- giant 1.75 tyres/tubes > tioga powerblocks 1.6/tioga tubes
- alloy seat post cut in half & steel stand removed
So far it's been stripped and bearing preloads adjusted, found a good deal of grease on all bearings and in the nexus hub which was good to see! For nexus 3 speed ratio adjustment I tried shimano for a bigger rear cog but none in country. That made ditching the original cranks an easier choice so I went with sinz square taper 125mm crank arms and a smaller 35t front chainring (down from 38t) which should make it better gearing all round. Two gears now for climbing instead of how giant sets them up with middle gear for flat, then either side for up/down hills. Better off coasting down after spinning out, and having 2 dedicated for climbing gears I'm thinking.
So far over 2.5kg lighter and my crappy old scale puts it close to 7.5kg. Over 1kg reduction in the tyres/tubes alone from the giant wire bead to the tioga folding and light tubes. Should be better for our 10km spins than the little 16" hotrocks that she flies around on now!
Next:
- bbg 36t 110 bash guard to keep chain away from legs http://www.bbgbashguard.com/Cyclocross.html
- hope seatpost clamp that's somewhere in the bottom of the spares box.
- wellgo m138 mag pedals
- fleabay 25.4 alloy riser bar to replace the giant steel bar.
Should be about 7kg finished, not too bad for a 20" bike. Hmm, 36 spokes also seems overkill, surely 18 will do.....
scblack
Leucocholic
Bought my 7 year old daughter this last night. 7speed and quite heavy. 24inch wheels.
Beautiful paint colour and finish.
