Jabubu
let you google that for me
It was pleased to see me!Look how erect that seat post is!!!
The pressure relief is a thing but I reckon the main benefit of the port in the durolux is that you can thread in a syringe and push some oil in to freshen the dust wipers.Mine hasn't arrived just yet, but I dare say it'll be the same... I was just thinking out loud.
Yeah that port is right up in the seals... probably just as well as the Durolux doesn't have an oil bath, just grease. Which makes me a bit sceptical...The pressure relief is a thing but I reckon the main benefit of the port in the durolux is that you can thread in a syringe and push some oil in to freshen the dust wipers.
the shop didn't use Stans sealant so I couldn't use my Stans DART to plug it.
Yeah. I feel that. I hate when my mechanic uses premium air in my tyres during a service and I can’t top them up at home with normal air.
Unless I'm mistaken, doesn't the Stans DART react with Stans sealant to create an effective plug?
Update: Nope (CftF)Unless I'm mistaken, doesn't the Stans DART react with Stans sealant to create an effective plug?
Its just a plug that works with any sealant. I've tried a few different plug kits, Stans, Dynaplug etc... I prefer the bacon strips. Bigger holes, use 2 or 3.Update: Nope (CftF)
Awesome mate. You learned. I laughed. Awesome.Update: Nope (CftF)
I bought a couple of these, and rate them.0.76AU $ 89% OFF|Rim Repair Kit|bike Tubeless Tire Repair Kit - Plug Stopper & Rubber Bacon Strips
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
0.76AU $ 83% OFF|Rubber Strips Repair Bicycle Punctures | Bicycle Puncture Repair Kit Tubeless - 50pcs - Aliexpress
I got caught out like that a few years ago, I managed to throw myself sideways off the trail so I didn't fall back-first onto the rocks. The problem with the side of the trail was that someone had cut a heap of brush and laid it over the cut stumps, I managed to miss the stumps but fell into the cut brush and was stuck there upside down with my backpack tangled in the branches.I also did an XC crash - seat post right up, aiming to boost up a rock outcrop on a climb. I stalled and forgot to drop the seat post which led to me being tilted off the bike backwards. The more the bike fell back, the more the ground got further away until I fell into some soft undergrowth.. Thanks fuck there weren't any stinging trees there!
Perhaps these new fangled wireless droppers should come with a gyroscope!I got caught out like that a few years ago, I managed to throw myself sideways off the trail so I didn't fall back-first onto the rocks. The problem with the side of the trail was that someone had cut a heap of brush and laid it over the cut stumps, I managed to miss the stumps but fell into the cut brush and was stuck there upside down with my backpack tangled in the branches.
The issue is the little needle can't take any fatter strips but you can put multiple of the lil bacons in.I bought a couple of these, and rate them.
Cheap enough to give away when someone doesn’t have one on the trail. Or to keep one strapped to each bike with tubeless tyres.
Been meaning to try and pull some strands off a car sized bacon strip, just to see if I can make some slightly thicker ones for the bigger holes.
Apocalyptic rides!
I cut car ones into pieces 1” long then in 1/2 diagonally so they are long thin wedges. Not for use on the trail but for home repairs on tyres with small cuts. Push the thin end through from the inside, and pull through until too fat to pull through any further. Ensured they don’t pop out under pressure like I’ve very occasionally see a bacon strip do.I bought a couple of these, and rate them.
Probably depends on the casing and the hole size. DD or equivalent casing with small holes mightn’t have that patch issue. Dunno, never tried it. I’ve never stitched and can’t say I ever will. If a cut is big enough to warrant that, it’s gonski.Not a bad idea there @moorey !
Proper car tyre plugs are internal mushroom things that don’t pull through just like your diagonal strips. Will have to try it.
I’ve tended to hand sew (well, using hand & pliers) good quality tyres I wanted to keep using when they have a tear, then patch from the inside. If you don’t sew them, the patches eventually push through the hole and puncture again because they have no reinforcement plys in them.
